I have recently bought an Asus Direct CU Top 5850 (because it cost very little more than the reference card), apparently these are quite decent overclockers. I currently have it running as standard (765mhz gpu clock, 1125mhz memory clock)
For now, I don't want to change any voltages. I have found some overclocks on this review http://www.pureoverclock.com/review.php?id=954&page=15
Can I just use catalyst control center to increase the gpu clock to 900mhz, and memory to 1200mhz... and then test it? (run furmark for 15mins)... or is there something else I should do?
thanks
thanks
ill have a look at doing that now, thanks
