Hi all im about to DIY my first build and well i have a bit of a problem i have never had to setup a HDD before with software.My old build was driver less IDE.
So what do i need to do on my new system? Im guessing that there is a F6 AHCI driver but what is it called? And what is intel RST? I presume that one would install the F6 driver in windows 7 install and then once done run the intel RST like any other chipset driver? My motherboard is Asus Z77VPRO and im so confused as to what to setup and what software i need to get max performance :/ I find the following on Asus website.
Asmedia SATA Controller Driver ( no idea what this is)
Intel Rapid Start Technology Software ( no idea what this is)
Intel(R) Rapid Storage Technology Driver Software V11.1.0.1006 for Windows XP/7 32bit & 64bit.(WHQL)
Intel(R) AHCI/RAID Driver for Windows XP/7 32bit & 64bit.
Im not sure if the above RST is an exe you run outside windows or is it the F6 driver i put on my usb pen?
