How do I reduce PSU noise?
The power supply will increase the fan rpm as the temperature increases.
You will ideally need better ventilation so that more cool air is available inside your case for the psu to take in. This way it won't get as hot & the fan won't have to spin up as fast.
But to be fair, we probably need to see your full system specs to properly advise.
Oh I didn't really see why getting a good PSU was necessary, it's just supplying power...
My system temperature stays at about 25C and the PSU fan never changes. Which other ones have controllable fans?
Fail PSU, get something branded.
Ive had no ends of cheapy psu's go from people saying "I dont want to spend much, how about this £20 unit?"
If you havent had it long (under 7/14 days) return it under DSR.
DSR = Distance Selling Regulations
Whats your system spec? Will be the only way to spec you a PSU.
That Noise kit will only help vibration. To see if it will do anything, push down on the PSU while its on.
And this is my current set-up:
Intel Core i7-2700K
Sapphire ATI Radeon HD 6950
Asus P8Z68-V PRO GEN3
Antec Dark Fleet Series DF30 Case
Antec Kúhler H2O 920
OCZ Agility 3 SSD
OcUK Crusade 750W PSU
Kingston HyperX Genesis Grey 8GB
You seriously need to listen to the advice, with nice hardware like yours you should be using a quality PSU, its the one item you should never cheap out on.
Please can you explain better why it's bad to have a cheap PSU. I don't see any vast benefits on the better ones. My current OcUK one has short circuit and over voltage protection
yeah, it is JUST supplying the power to all the other components that you have spent a great deal of time researching and reading reviews of and then spending your hard earned cash on
its like deciding to build your own dream house and going cheap on the mortar to hold the whole lot together - i;d rather skrimp and save on the mobo/case/heatsink rather than the power supply
you could open it up and change the fan for a noctua fan,it might just unplug or you might need to unsolder it,and opening it up would void the psu warranty,but its an easy job
as for cheapo psu's theres good and bad,ive used one for 3 years with my i7 x58 system and its been flawless, a 1050w unit for £45,but there are some really bad units out there
But OC aren't going to besmirch their name by selling a PSU that's just going to die on you. What are the benefits of spending a minimum of £30 more?
