how do i remove write protect from an Micro SD Card ?
5 Aug 2006
Northern Ireland
ive tried the diskpart way and format but nothing works just fails and still says write protected on x2 16gb micro sd cards from what i had in my phones and i dont know how this happens or how to unlock it so i can format them, please if any one knows an app or something that would be awesome :)
thanks
thanks
If it's encrypted when you use diskpart to delete the partition use override so...
Delete partition 1 override
If you are using a microSD to SD adapter, make sure the Lock switch on the left side of the adapter card is slid up (unlock position). You will NOT be able to modify or delete the contents on the memory card if it is locked.
