How do i rename 100's of files.
7 Oct 2003
Nottingham
Don't know if this is the forum but here goes :)
I've downloaded 100's of images from usenet but unfortunately the filenames came out looking like this
and so on.....
what i would like to do is move the "1.jpg" etc. into a folder and rename "Copy(1) of 1.jpg" etc. to "1.jpg" etc. and move those into a folder and repeat the process until there all sorted out.
Is there anyway of doing this other than renaming each file individually (would take days) i.e. a program that will batch delete "Copy(1) of " out of the filename.
Thanks guys
if you highlight them all hold shift and rename in explorer, it'll rename them all to whatever you call them but with (#) on the end.
So if you've got a load of pictures of cars and a load of pictures of sheep, you could highlight all the car pictures and rename them as car(1),car(2) etc. like this.
Thanks
I know about that way but to be honest ReNamer is perfect for my needs and i need to keep the original file name :)
How does renamer work?
I put a file in called sf01.jpg and sf02.jpg and it it renamed them the same?
