How do i reset the Killswitch on my router?
19 Oct 2002
Woolyback Country
Basically the Killswitch on my dd-wrt flashed router works as it should(when the VPN drops so does the internet access
What I am after is how do I get the router to reset the killswitch/vpn ?
(reneg-sec 0
persist-tun
persist-key
ping 5
ping-exit 30
nobind
comp-lzo adaptive
remote-random
ns-cert-type server
route-metric 1)
The above is needed as part of the ovpn setup,do I just add/delete something to get it to reset/try again?
Noob at this stuff :o
I haven't done this before so have no specific knowledge that can help you km afraid, but you might have more luck in the Networking section. We can move it there if you like, just use the report to moderator feature if you want us to do it.
