How do I resize a picture?
22 Jun 2005
Nottinghamshire
I have some high resolution pictures that I want to resize to fit on a printout that's 125mmx65mm.
Essentially I want to shrink the picture and crop it down to that size, Can I do this without photoshop? I am running osx.
Thanks.
My usual method (may be a better way, I'm no PS guru)
1. Create a new image of the desired size, make sure you set dpi to at least 300.
2. Paste image in and resize/crop as required.
3. Save
4. ?????
5. Profit.
Is this on a Windows machine? If you have Office, you can do this with Office Picture Manager.
Probably won't be as good a quality as Photoshop/GIMP, but it might suit your needs?
Edit: A bit more involved alternative is to use the Command Line and ImageMagick - this link gives an idea of how to resize a source image.
You could probably create a script to do this regularly if required.
he's using OSX, says in the first post :p
Haha I'll blame it on it being Monday!
In that case, OP can use Preview. Under the Tools menu, choose Adjust Size.
Have a look at Automator too - you can create a workflow to do this automatically.
Also, ImageMagick point still applies as there's an OS X binary for it.
