How do i tell if my power supply is not big enough?
16 Dec 2009
Right now i have a 700Watt PSU powering my gaming rig.
(AMD PHENOM II X4 955 @3.65GHZ,
4GB DDR3 1333MHZ RAM @1550MHZ,
1GB ATI RADEON 5870,
500GB HARD DRIVE,
DVD-RW.
Also my case has like ... 6 fans)
My voltages read as so...
vcore1: 3.76V
vcore2: 3.68V
+3.3V: 1.81V
+5V: 3.66V
+12V: 6.53V
are the voltages being WAY off saying my power supply is overtaxed?
P.S - if it is can anyone recommend me a decent PSU for my spec machine?
Thanks.
I do not take any notice of software readings for voltages, at the moment my 12v line is reading 4.93v according HW monitor and Speed fan ect read the same.
Only use a multimeter to check.
A 600w will be fine for your setup :)
Thanks for the advice guys. just checked with a multimeter.
+12V: 12.2V
+5V: 5.0V
