Ok current clocks are as:
4400X2 @
2420.1Mhz
X11 Multi
FSB 220MHZ
Corsair 1GB Pro 220Mhz 2-3-2-6-8 Timings
Ok I can get the CPU to about 2.6 but then the system isnt quiet but im up for a week of no sleep to get this done.
I need to decode some videos ASAP
Of 66 parts to encode takes 4hours to do in blocks of 7.
Which are better settings to go for. Higher Mhz on the CPU is simple but should I go for higher RAM speed or tight timings?
Quick reply if possible thanks.
4400X2 @
2420.1Mhz
X11 Multi
FSB 220MHZ
