how do i use 3G on PAYG?
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
i am on orange pay as you go on a N95, and sometimes i pay £1 for 24 hours access to the net. But it's not very fast as you expect, i know 3G can do a lot faster than that, is there anyway to use it on pay as you go, while on the £1 24 hours unlimited?
which one is better? Dual or utms?
Dual. If you select UMTS, it will only pick up 3G signals, and if you aren't in a 3G area, it basically means you'll have no reception. Dual will connect to a 3G network first, and if it can't, it will try for a 2G connection.
