I
think that I make great burgers. They are so so easy. I tried to replicate 5 guys.
The simplest burger is this:
Beef mince (5%-10% fat), salt, pepper, mix them all together. Split it into balls, then flatten them with your hands until they're maybe 1 cm thick. Fry for maybe 5 minutes.
The best burger is this:
Dice some bacon. Fry it, basically to the stage where you'd be happy to eat it as it won't really cook any more when it's in the burgers.
Beef mince (5%-10% fat), add your bacon, salt, pepper, mix them all together. Split it into balls, then flatten them with your hands until they're maybe 1 cm thick. Fry for maybe 5 minutes.
No need for eggs or bread crumbs.
One thing that I do add sometimes is a little garlic salt and onion granules. I used to add mustard, but I've found the less you take away from the beef taste, the better.
Well I've just discovered a burger press. Not sure if it squeezes water and fat out but should compact the burger.
In my experience, burger presses make the burgers too thick and not large enough. I would consider using one and then flattening the burger out more because they ALWAYS shrink when you cook them.
