Hi,
Well I got a buffing pad that fits onto the drill, I also know it needs to spin about 1800rpm iirc. So how do you polish using a buffer? You stick the polish onto the paintwork and then use the buffer to work it in? Then use a new pad to buff it out when dry?
one panel at a time, and when it's nearly dry, buff it off. You can get away with one pad then.
