- 24 Jun 2003
Hi can you's please check out my basket and make sure it all works together , and also would you change anything ?? i do try to plan and overclock a bit if possible , but most of all i want stability.
My basket at Overclockers UK:
comments ?
edit also do i need thermal paste ??
- 1 x Gigabyte GeForce GTX 1080Ti Gaming OC BLACK 11264MB GDDR5X PCI-Express Graphics Card= £578.99
- 1 x Asus Prime X470-Pro AMD X470 (Socket AM4) DDR4 ATX Motherboard= £158.99
- 1 x AMD Ryzen 7 Eight Core 2700X 4.35GHz (Socket AM4) Processor - Retail= £299.99
- 1 x Team Group Dark Pro "8Pack Edition" 16GB (2x8GB) DDR4 PC4-25600C14 3200MHz Dual Channel Kit - Black/= £218.99
- 1 x Corsair Hydro Series H100i PRO RGB Performance Liquid Cooler - 240mm= £114.95
comments ?
