how does this rig sound?
4 Nov 2004
Norwich
Processor (CPU)
AMD ATHLON™ 64 X2 4200+ (2.2GHz) 2 x 512K L2 Cache (AM2 pin)
Memory (RAM)
1024 MB CORSAIR DDR2 800MHz - (2x512MB)
Motherboard
ASUS® M2N4-SLI: DUAL DDR II, S-ATA II, 2 x x16 VGA, 2 PCI
Operating System
MICROSOFT® WINDOWS® XP HOME (inc. Genuine CD & licence)
Memory - 1st Hard Disk
160GB SERIAL ATA II HARD DRIVE WITH 8MB CACHE (7200rpm)
CD/DVD Drive
16x +/- DVD WRITER (8x +/- Dual Lyr) (5x DVD-RAM) (40x CD-RW)
Graphics Card
512MB GEFORCE 7900GTX PCI Express + DVI + TV-OUT
WIRELESS 108Mbps NETWORK CARD
Power Supply & cooling
500W (Peak) Super Quiet Dual Rail PSU with 120mm fan
Printer
HP PHOTOSMART C4180 ALL-IN-ONE SERIES
this will be built for me, but will be built for gaming. the cost was £1048 delivered. I don't know if i will really need that graphics card, the alternaltive will be a 256MB GEFORCE 7900GT PCI Express + DVI + DVI + TV-OUT for £150 less??
prices are also with the printer. alternaltively do this build and have a go at building it myself and buying a printer on top 888888888888g[/url]
I'm been getting my head around what to do all day I've gone from just upgrading my current pc to buying a whole new rig, so my brain is pretty fried now.
Looks good, if it was me i would have gone with a bigger HD, but its your choice. maybe even do a raid
A few suggestions, I would seriously consider getting a different hard drive - take a look at the Seagate 7200.10 range.
I would also consider getting a different power supply. Reason being that its not a very high wattage and I'm sure I've heard people having problem with it overheating due to its fanless design, plus its rather expensive because of this. Ones to look for are Tagan, OCZ, Seasonic, Enermax....
Lastly, edit that screenshot (*graphics card*)
the screenshot if you click on it it'll resize. basically my problem is as I'm spending more than i expected I need to get the pc on finance, not being in touch with my inner pc self I'm relying on the forums help. and I know recommending kit not from OCUK is not allowed which makes builds difficult.
