So I've had my pc for couple of years running on watercooling with soft tubing and i finally decided to try and change it to solid tube. I am kind of wondering how hard would it be for me to make the bends and which tubing is better for starter, Acrylic or PETG. My longest run by my calculations would be around 50-60cm from pump to top 360 rad. I wondering what kind of tools i would need and what would be est tubing and fitting size for a new guy like me into solid tube watercooling.
Thanks
Here's my pc right now: https://imgur.com/a/iVsdY
Spec:
CPU: Intel i7 3930k
Motherboard: Asus Rampage IV Extreme
RAM: Corsair Dominator Platinum 16gb(4x4gb) 2133
GPU: Gtx Titan 6gb
PSU: Corsair AX860i
SSD: Samsung Evo 850 500gb x2
HDD: WD Black 4tb
Thanks
Spec:
CPU: Intel i7 3930k
GPU: Gtx Titan 6gb
PSU: Corsair AX860i
HDD: WD Black 4tb
