Stellios said:Mind you dont fry your nuts![]()
Well I've just had a look, and MBM claims I'm running 11.33 and speedfan seems to think 10.82 :/sr4470 said:11.78v is well outside normal range for a 12v line. I'm not sure it would be so stable running something more intensive than web browsing...
Flibster said:95°C CPU
and
65°C HDD
On my Laptop at the moment...
3.33Ghz Desktop Prescott chip in it so a little bit toasty...
OCdt Stringy said:Well I've just had a look, and MBM claims I'm running 11.33 and speedfan seems to think 10.82 :/
While they both sound ridiculously unhealthy I've been playing Hitman: Blood Money all day, and haven't had any problems with my computer recently at all - so it's probably a misreading.
Raikiri said:down to 11.4vis ok, it is +/-5%
Raikiri said:A little?!
Raikiri said:Never said it was, but check the ATX specification. +/- 5% is apparently fine.
Haly said:CPU's at about 49C so about 6C over usual.
Mind you it's a P4 2.4ghz OCed to 3ghz with stock cooling so I should probably get some extra cooling sorted out one day![]()
CPU idle: 39 (newcastle 3500+ at 2.65Ghzbasmic said:Mine, at mostly-idle, are:
CPU: 43c
Mobo: 32c
GPU core: 50c
GPU PCB: 38c
