How hot is too hot (Rackmount hub)?
18 Jan 2006
Norwich
Slightly random question :p
I've picked up a load of 16-port rackmount hubs from the MM.
One of these is unbranded, & has a nasty little fan inside (Chipset sized thing). This is sitting next to the PSU (Switching, 6/3v iirc), & there is also a chip with a large heatsink on the far side of the board. With the fan unplugged after about an hours operation, the PSU shielding & the heatsink are hot, but not uncomfortably hot to the touch, with the case staying cool.
Anyone care to comment on how hot is too hot?
I'm tempted to rip the fan out, it doesn't seem to be doing anything much more than making a racket.
Cheers
-Leezer-
Is this in an air conditioned comms? Is the switch "loaded up" much?
If it's in a cool room probably get away with it but to be honest really, is it worth the risk?
Sitting under the telly lol.
I'd say a low to medium load, high in the evenings :) (Torrents, file sharing, media streaming to various rooms, 20mb net should give you a decent idea)
Room temp normally sits about 15-19 degrees.
The airflow it provides is TBQH peanuts, but I've considered replacing the fan, 40mm size sounds about right without a ruler. Having said that though, I've never found a quiet fan at this size, which is much of the reason I'm considering simply ripping it out.
Cheers
-Leezer-
To be honest, i'd just ditch it and get a fanless switch instead of using a hub.
I picked up a 24 port 3Com Superstack for £20 a few years ago which was fanless, the Superstacks i have now are not fanless, in fact they're very noisy but were £11 each.
