How I Solved My YouTube Problem.
Permabanned
26 Oct 2006
Birmingham
YouTube isn't the only problem i solved. The problem was that my uncle wanted to cut a song out of a music video, we were searching for awhile and after countless programs that gave you half the song or were either demo's we finally stumbled across two handy programs that solved all your problems!
The 2 Programs That Solved All.
  • - Virtual Dub
    2 - WinAvi Converter
Yes these two small but very effective programs helped me and my uncle both launch video's onto YouTube.
How I Did It With Virtual Dub.
  • 2 - Pull the bar to where the song starts
  • 4 - Press the 2nd last button on the bottom bar.
  • Pull the bar to the end of the song
  • Press the last button at the bottom of the screen
  • Click Start and save the .Avi file
  • 8 - A dialog box should go up, it should show the progress of how long it has got until it cuts the bit you want.
The file will be around ???GB when finished
How i did it with WinAvi Converter
  • 2 - Click convert to WMA,Avi,MPEG or the format of your choise (i usually use AVI)
  • 2 - Save where you want the OutPut file to go.
  • 3 - Click Next
  • 4 - It Should Start.
    5 - When finished click ok and close the program.
The file should now be under 100MB!
This is more or less the way to cut a song or video clip from a CD and put it onto YouTube, it doesn't take long and it is well worth it after. The quality is the same (usually) and best of all it is absolutely free!
I hope you found this guide usefull. :)
PS: if you have any other suggestions i will gladly edit this post and add your bit into it.
G0dfather
One more thing, WinAvi converter can also burn your VCD/DVD/SVCD and also can "batch convert". An excellent program to have to say the least.
G0dfather.
