How important is ACHI?
21 Apr 2012
Hi guys,
first off - christ SSDs are fast! Definitely one of those things you believe people about but even better seeing it in the flesh.
But onto ACHI. I was told to set my bios to this before installing windows but I forgot. Before I go loading everything onto my computer so I need to go back and reinstall Windows again?
Cheers boss.
Another quickie. I've got my SSD plugged in which I installed Windows on and then plugged the HDD in with the same connectors into the same socket on the motherboard but Windows isn't showing it up.
Any ideas?
*edit* is the difference between ACHI and not-ACHI big?
ok i have now read conflicting reports on it some say yes do it some say dont bother
i cant use it cause if i do it messes up my multi boot and my ssd is fast as hell anyway so rather than configure all my drives or risk messing the multi boot mines in ide mode and its not sufferng that i can notice.
i guess most will say run it in ACHI mode tho its just i cant
Cheers boss.
Any ideas?
No problem.
You need to go into Disk Management (Right click Computer, select Manage and then select Disk Management), right click on the unallocated space and create a simple volume.
From what I've read AHCI mode gives the best performance.
OR
the SSD is scorching quick in both IDE and/or AHCI mode
it's just from benchmark tests - AHCI will give you the BETTER overall performance.
don't lose loads of sleep over it :)
Lastly ..... ENJOY !!!! :)
yeh AHCI is deffo better.
I did what you did and tried to swap it in windows after but it made my boot times really slow. So last night i formatted my SSD and re-installed windows as i had a new mobo and gpu as well so thought i had better.
Windows index in IDE was 7.5, when i swapped it to AHCI it is now 7.9
Ignore Windows Index scores
you'll find that they can and do change with updates from MS. Not a very good way to guage performance of your rig IMO
i think its fine on a single boot system to make them AHCI then that would be a yes
but its not working on a mutli boot system i think you need to keep them in ide modes or you lose the other drives from regitering for some reason well i do i need to mess with it and find out why
