How important is class to micro sdhc card?
Caporegime
13 Jan 2010
Llaneirwg
In real life is there going to be any benefits from getting a class 10 to a class 4?
I understand the difference in spec
Nothing really. Just really impacts copying time from pc for me. 64GB Class 10 is 35 quid on rainforest so a no brainer.
I don't know if my phone accepts 64.it doesn't on its specs and I have read some people are Ok. Others are not.
I've never noticed class 10 being fantastically quick, but i do notice other classes being fantastically slow.
The shizzle ones of famous auction sites for a matter of pence transfers at 1 bit per year.
Class 2 slowed my Xperia phone pretty badly since most of the apps was on there (low internal memory sucks). Moving to Class 4 helped quite a bit, but it still felt slow. I would say go grab a Class 10 micro SD if you plan to move apps onto it (if your phone supports app2sd).
I won't need apps on sd as the phone has 32gb, it will only be media.
So avoid class 2, use class 10 if you need fast transfer speeds/apps on sd?
The class just means the minimum write speed, so a class 2 is 2MB/s minimum, a class 10 is 10MB/s minimum.
SanDisc are pretty much bang on the minimum (for write speed, can't remember what the read speed was on them) but are well priced, £35 for 64GB as said above, Samsung are faster, something like 20MB/s write and 70MB/s read but more expensive.
I use a class 10 Sandisc, like most here I think, as they're easily fast enough and well priced :).
I can't see needing a fast card if it only has real benefit on file transfer (setup sync to microserver everyday at 7am via wireless)
I'll have to look into if 64gb is Ok on my phone otherwise just stick to 32
There can be a major difference between the speeds of different micro sdhc cards....
You really no want a slow micro sdhc card as it will forever to transfer data to & from it...
(I had the joy of owning very slow memory cards before :()
And also don't go by just what class or price they are,as one brand class 10 card can have very different speed to another brand class 10 card..
Look up for reviews first of any cards that your interested in
Well transfer speed and isn't too important as long as it doesn't impact phone performance
