how is this spec for £750 ??
22 Nov 2010
Kettering
hey guys, so my dad bought me a msi p55 GD80 as one of my xmas gifts and i am getting my money to finish the build on wednesday so i have made a basket of componets and added a keyboard and mouse as mine have about had it :(
anyway here it is
intel i5 760
corsair xms3 2x2gb 1600mhz
xfx ATI radeon 6950
xfx pro 750w
zalman z9 plus
corsair h50
samsung spinpoint f3 1TB
razer deathadder
razer lycosa
now all this with out postage as i get it free is £748
is there any changes you would do to that spec ??
i want to keep the same keyboard and mouse tho
cheers fellas
beasty
I would probably not bother with a H50 and get a <£40 air cooler (Titan Fenrir, Heatsink + quiet fan), or consider the Antec Kuhler 620 instead.
Don't really like the looks of the case but it's subjective :) Seems to be well engineered. Hope the 6950 will fit.
Shame this wasn't a Sandy motherboard, even with a broken Cougar Point. Would be a crass thing to sell the mobo and go Sandy though.
Apart from that... seems sensible enough. Maybe some nice speakers, like the Edifier R1600T.
EDIT : may need some thermal compound with the Kuhler.
can u return the p55 gd80 and get a sandybridge mobo and cpu instead? that would be faster, if not the i5 760 is still a fast chip. Apart from that it looks like a good build.
i;d go sandy bridge for two reasons:
- incredible performance and overclocking potential
- less heat so can get away with mid-air cooler
and your dad surely bought that mobo for you becuase he thought it was the best, so im sure he would understand that your trading it in for a different model that is more to your specific needs :p
Quite no need to spend so much on a keyboard - the Sidewinder X4 gets better reviews, is cheaper and not being Razer is less likely to break.
For £1 more you can get the Cyborg V5 which CustomPC actually rates as being the best gaming keyboard around.
I agree with Olivier on the cooler - and Kuhler 620 is an updated version of the H50 that out-performs it significantly. However, a Akasa Venom or Titan Fenrir will both do the job more than adequately!
Rest looks very good though (even if I can't stand Razer :p)
yeh i planned to go with the i5 760 for quite some time so my old man got me the mobo :)
my partners bro has the razer deathadder and lycosa keyboard and i really like the looks and how it feels when gaming
gpu wise, is the 6950 a good choice and will it be ok with the case and build ?? or maybe a gtx480 ??
also im going to be gaming on a 26" sony HD 1080p TV soon so again card ??
beasty
HD6950 2GB version can be flashed to a HD6970.
Decent choice, overkill for 1080p but there won't be anything you can't max.
GTX480 gives slightly better frames but uses A LOT more power and is significantly hotter.
ok thanks guys :)
also i have taken the advice and changed the cooler the the antec kuhler 620 :D also anyone know when these are instock ??
cheers guys
beasty
ok thanks guys :)
cheers guys
beasty
That's one thing though, maybe best to ask Overclockers about availability. You could always go with a retail CPU, use the supplied cooler, and upgrade and OC later. Maybe worth waiting to get some user feedback before (reliability, noise, ect...) since it's relatively new tech.
However, the Antec and the H50 requires some work on the backplate but the Zalman has a nice big cutaway at the back for easy access.
If you do have the possibility to change for Sandybridge i5-2500K, you'll get all round package. The HD6950 is good, and you can also go for the 560ti, there isn't much in them. That 6950 does have 2GB ram.
Personally I wouldn't go for the 480, unless you want pure performance, but for me power consumption, noise and heat are also important.
a i5-2500K basket.
Your Basket
1 x XFX ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card £199.98
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail with FREE Shogun 2 Game £179.99
1 x Asus P8P67 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £124.98
1 x Antec TruePower New Modular 750W Power Supply - With FREE 3D Mark 2011 Advance £87.98
1 x Coolermaster CM-690 II Lite Dominator Case - Black £57.98
1 x Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £43.99
1 x Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD105SI) £38.98
Total : £746.48 (includes shipping : £10.50).
You can even add a couple of fans in there. It's a shame OcUK don't have the windowed version of the case.
The things like the cooler, keyboard and mouse can be added later at no detriment to the rest of the build, but if you want a Sandy within your budget, you'll have to make due with this, use your current stuff for a while, and upgrade the other components later. Sell you 1156 (don't think you can just return it but it's worth a try) to get a bit of money back, maybe towards the keyboard and mouse. As a core system that's got a lot of power and legs to carry it for a few years.
A stock cooler on i5 is perfectly fine, and overclocking can be something you can do later but it's unlikely your system will lack in the power department.
Just an idea.
