How large can they get?
8 Apr 2012
Hi guys, this may seem like an odd question, but does anyone know what the maximum width that a vehicle can be for traveling on UK roads? From there if anyone could estimate the maximum height you could make it without compromising stability, then that would also be very helpful. I'm sorry that I cannot give further information at this time, but the details of what I am working on have been marked as confidential.
Thanks in advance for all help (and mocking, ridicule and anything else that makes me laugh :p ).
TV Police
On motorways and 'link dual carriageways', loads up to 4.6 metres wide or 130 tonnes will normally be allowed to move without an escort. On other roads, it is up to 4.1 metres wide or 80 tonnes.
No doubt there are regulations for when you need an non-Police escort
Okay, So my organisation could build a hovercraft with a width of four metres without needing an escort, what sort of height could we make it without it falling over, if we keep the centre of mavity as low as possible?
Please feel free to take the ****, it may well be a silly idea anyway, but from a couple of teenagers with no grounding in reality expecting much else is equally foolish. Am I crazy for taking this part of my warped mind seriously?
Probably taller than you would think but it's impossible to give you any sort of actual figure as it depends on so many things, such as what you would define as 'stable', what suspension set up you were using, weight distribution etc. etc. etc.
Thinking about it, the controls are so different, what kind of license am I (and the others) going to need? For the insurance, wouldn't the premiums be lower because if you hit someone you would just bounce off the air cushion?
WTF.
Will a hovercraft corner well enough? Surely it's all well and good in an open space but on a public road? You're going to drift into a hedge.
And the stopping distance will be about 4 miles.
