How long can a usb cable be?
Trigger said:
To be honest, I don't know but I've tested it and it doesn't work. At a guess, I would say it is caused by voltage drop but I can't be certain.
I personally think it would work, but that is just my guess
As long as a piece of string......
Too many different variables to give a concise answer.
- quality of USB chipset
- condition of sockets and plugs
- quality of cable
- number of cables
I currently have a 5m + 3m + 3m + 2m cable from my PC to a media player on the other side of the room.
You can also get extenders which are basically cables with an integrated signal amplifier.
I've tried repeaters before and found that they very rarely work very well. We also tried lots of different makes of both cable and repeater and couldn't get it above 15m. We even tried just putting it on the floor out of the trunking so environment has nothing to do with it either.
