Depending on the type of domain, it can take a while to transfer the registration. Typically, for a .com you're looking at up to 7 days.
For a simple nameserver change though, you're looking at upto 24 hours for DNS propagation.
In terms of using your webspace temporarily, you should be able to connect to the IP address given in your FTP client with your cPanel username and password. If this doesn't work, give support a shout and they'll be happy to help.
