it puts my mind at rest, but i really hope it was a 40mph limit, thing was.. it was on a slope (like going under an overpass)
Still worried about it![]()
I was utterly and completely convinced they had to issue (ie make) the ticket within 14 days and from there in they could take as long as they like (within reason) to get it to you?
They have 14 days to issue it plus they get time to deliver it, I think the wording is 'in the normal course of the post'. That means they have about 2 days to get it to you after the 14 they have to issue it.
Yea 45 indicated should be fine, I was doing 82 indicated on a motorway so not so sure ill get off![]()
If your speedo said 45 you should be fine, ACPO guidelines say they don't prosecute unless you're going 10% + 2mph over (so 46 in a 40) - but your speedo will overread anyway.
