How many amps to turn an engine over?
My Scorpio has the 2.9l 24v BOB Cosworth engine and the starter motor is 1400w with a 72ah 720cca battery fitted.
Assuming 12v then 1400W is 116 amps.
The CCA rating is based on. most are 6 cell batteries so then you only need to maintain 7.2v, I dont know if many cars would actually start with such low volts.
"the battery in a cold environment (0°F/-18°C) and the discharge load in amperes that a new, fully-charged battery can deliver for 30 seconds, while still maintaining terminal voltage equal to or higher than 1.20 volts per cell"
