I'm getting hardline loop with 3x ek pe 360mm rads, asus Ix formula motherboard block, ek elite 1151 cpu block, alpha cool m.2 water block, 1080ti ekwb waterblock, is one ekwb pwm elite Ddc pump res combo enough?
I have a similar setup regarding rad space and blocks and I've used two pumps but both turned down to 2 for years, I only originally put 2 in as at the time the deal was too good to pass up.
D5 has good flow rate, EKs top whack DDC has better head pressure - which is great if you've got lots of Hard Tubing bends
M.2 block will be the slightly restrictive but put the D5 on setting 4 and off you go
