How many Processes on boot?
26 Jan 2006
Belfast
With a couple of things open I seem to have about 70 processes running, and using about 1.6gb of ram..is this about right?..seems a lot!
You're going to need to provide more information that that.. which OS, 32/64 bit, a list of the processes (screenshot of taskmanager or tasklist from command prompt) etc. If you're on Vista/Windows 7 they aim to use all your free memory rather than leave it wasted doing nothing.
I have about 100 on startup on Windows 7 64-bit so I'm sure 70 is fine.
My god :eek:. I have 41 on startup. Using Windows 7 Professional 64-bit.
I thought that was too much as I have all the logitech setpoint, microsoft lifecam and google updater crap running at startup.
100 is just insane lol! That's 60 more EXEs than me!!! SIXTY!
Just checked my task manager and I have 36 running, using 1.45 Gb (Win7 Ultimate 64bit).
Do you have a lot of stuff in your taskbar?
Or a lot of programs set to check for updates automatically?
Are you running a lot of services also?
Are you showing processes from all users though? I'd be shocked if it was that low if you were.
about 80 for me, razer software, my docks, dropbox, g15 keyboard software, remote desktop, gadgets, multi monitor software, all add up to over a minute of boot time on 2x velociraptors in RAID 0
I have 68 running now with IE and live messenger running. I don't think I had as low as 41 even with a clean install with no antivirus ect installed.
88 here and I have a fair amount of crap running! :p
Still, my Windows 7 64 is as responsive as the day I installed it.
I have found that in general Windows 7 has more processes and a lot more RAM being used compared to XP. Which is not surprising. Windows 7 is doing more and utilizes all your expensive RAM to make it such a snappy OS. :)
True. I am running 51 processes and ram consumption is 1.25GB out of 4GB in dual channel (30%). When I had 3GB ram, my ram usage was around 780-900MB:confused:.
104. This laptop seems to have quite a few drivers that come with running processes (touchscneen, digitizer, fingerprint reader, touchpad, quick launch keys etc.) :s
Yeah.
BTW the process counter in task manager shows the same number, whether "show processes from all users" is checked or not ;)
Not on my version of Windows 7, even with an admin account when I select to show all processes from all users I get an extra two!
windows 7 64bit, 2.2gb ram used, around 70processes but that's with theme applications, firefox, msn, spotify etc.
laptop has windows 7 32bit, msi u100 1gb ram in total, 735MB of ram used, with skype, msn open..
i currently have 39 processes on startup and thats using 32 bit windows 7....
your comp sounds like my fathers after he's been surfing the net for a couple of hours accepting any box that pops up,
sounds like you need a little more computer knowledge when surfing the net, also get ccleaner to clean your c drive occasionally, ccleaner is a free program and u D/L it free from http://www.ccleaner.com
It's not really insane at all, gone are the days of having less processes = Better. Modern OS + Modern Hardware = Careface.
Resources are supposed to be allocated and at the ready at all times, unlike in the XP days where they were sitting around idling..."free".
