How many tickets on a roll...
17 Mar 2005
London
Hey,
I did a quick search before posting and couldnt find anything to back it up...apologies if there is and also searched google!!
But basically me and a friend have decided we want to buy a full roll of lottery scratchcards from the shop...what we need to know is how many there are on a roll...either £1 or £2 cards,
Anyone know?
200 on a single £1 scratchcard reel and 50 on the big (£2-£5) ones.
I used to work on the tobacco/lottery kiosk at Tesco a few years back, may have changed since then.
Why not just throw your money into a bin instead?
*(Possibly)
Very true, well its something ive wanted to do for ages and I thought why the hell not, its only like staying in for one weekend anyways if its £100 or so (being around london)!!
Gotta have some fun, gonna combine this with some clever betting on the olympics (if thats even possible) and try to cover it with some sure bets that I hope come in!!
Probably 100 - my Mum used to own a newsagents I will ask her when I get home.
I would love to do this personally, maybe go halves with a mate - would be a bit of fun!
Rich
it depends on the shop
lots of smaller ones dont buy full rolls
especially of £5 ones
As far as i'm aware this can't be done if they are National Lottery (Lotto) scratchcards as the packs have to be activated on the machine before use. Unless they sold smaller packs of 100 or 25 etc which I am not aware that they ever did.
Hence if any idiot is thinking about nicking a load of scratchcards, it's a pointless exercise as if they aren't activated then you wont be able to claim, and even if they are activated, the serial number batch is logged and can be cancelled.
Ah right, maybe the newsagent just didnt want us to know how many £5 cards he had, just said he bought as few as he could at a time, maybe that was 50 cards
Its worth mentioning that a few regulars bought cards in bulk and as far as im aware (I asked them) they rarely broke even.
hmm.. I'll be interested to see how you get on!
Let us know when you get em and how well you do!
Contradictory no?
Very much so, but im sure you know what I mean, no bet is a sure thing but you can stack the odds by backing the (what should be) bankers to come in...
Well its planned for September to go mad, we are either gonna split a roll or go one roll each depending on how many on a roll and how much...probably gonna lose but you never know!! I did a similar thing last year on holiday and out of the first batch I was up £50 roughly, shoulda stopped but ploughed it all back in on different cards...
I was wondering if different cards or going the same card would be better or not...for this im sticking to the same card!!
Also, do your research, on the lottery website, they is a section to say what % each S/C has of winning a prize. Although you might not win a lot or you may win a lot. its worth getting a scratchcard that has the best % of winning a prize. Also, on Teletext it tells you how many of say £1000 prizes are available to that scratchcard etc.
For example, if a scratchcard has 10 prizes of £1000 to be won, Teletext will tell you that say 4 of those 10 prizes have been claimed/won. etc.
Me and my friend used to do it on lunch every Friday, put about £20-£30 each and buy £40-£60 worth of scratchcards, they was a few times we got up by about £80+ each, but a few where we broke even or just below.
But we used the lotto website and teletext and decided from there which scratchcards to go for. Tactics and Luck is what you need :)
Thats awesome, I knew about the lottery website info but not about teletext, I will use this to my info for sure, even if its not a huge difference to my odds of winning more, any little bit of extra info is worth it!!
This is gonna be so cool!!
Tbh it's a crazy idea, as 99% of the prizes give you less than 10x return.
My friend bought one at christmas, a £2 one, and won £100. We looked at the statistics in the retailer folder at work, and it had a 1 in 3,000 chance of happening.
There's usually 20m or so cards in a print run, and 65% are usually prizes. They make so much profit from each game, and there's a lot of games out at any one time.
