- 26 Dec 2009
- North
As above, what's the safe amount you can pull from a single / double socket?
And correct me if I'm wrong but each floor will be on a ring so you could use that amount off each floor?
So if it's 2000w for example, you could pull 2000 watt on each ring / floor?
I know it's more than 2000 as my portable heater uses that much plus have my pc/tv in same room.
