- 5 Jun 2007
- extremes.spacious.indelible
As per title, thinking of trying to teach myself piano, how much would a very basic one cost me?
A digital piano will cost probably £400 upwards. It's best not too skimp on this because you might end up getting a keyboard that doesn't feel right or cheap and will not inspire or motivate you to learn. It can have an effect or put you off especially at times when you're struggling.
Having said that you can, if that is an issue. You can do a kind of makeshift piano as in buy a midi controller keyboard (which has no sounds) and using your computer as the sound source. It depends which one you prefer, some people might not like using a computer and just want something they can turn on instantly.
Tell me your budget.
Just so you know, music out nowadays are relatively simple and don't need 88 keys to play it. So if you wish to learn these, you can get by with 49 keys.
