how much coolant
3 Mar 2013
hi I am thinking of doing my first proper water loop if I use two 240 or 280 radiators to cool cpu & one gpu roughly how much coolant does it take to fill. and is this a suitable pump XSPC Twin D5 Dual Bay Reservoir/Pump Combo thanks
My setup took just under 1 litre (as in only just under 1 litre!)
That's 2x graphics cards, 1x cpu block, a 360mm radiator and a 250mm EK tube reservoir (which is about 80% full)
For most loops, 1 litre is probably enough, but it's always worth having some spare, in case of leaks or if you decide to do something different later on.
