Don't judge me!were you rubbing it on the carpet?![]()
Which episode was that in?http://img705.imageshack.us/img705/9757/costumefamiyguyelectric.jpg[IMG]
I'AM ELECTRIC MAN!!!!
[IMG]http://img705.imageshack.us/i/costumefamiyguyelectric.jpg/
An electric shock is an electric shock. The only difference is that static shocks come from a static charge source, so they're instantaneous rather than continuous (and hence don't carry on as long as you're in contact with the source).
Tell that to lightning.
i'm pretty sure that the repetetive static shocks that the OP mentioned is just friction static and not lightning, you know, because he'd be dead if it were...
Static shocks is about 1,000 odd volts. They hurt but there not dangerous as they have extreamly little amperage.
I know this is incredibly pedantic, but lightning is friction static![]()
as a physicist i'm well versed in the precise way in which lightning is formed.
on the other hand, how else would you verbally differentiate between "lightning-grade" static and "slight-zap-on-the-finger-static"?
I know this is incredibly pedantic, but writing something on a forum isn't verbally differentiating
Also, no need to get so uptight about a light hearted comment
I've been getting a lot of static shocks recently and I was wondering how much damage they could do. If you got a shock to your eyeball could it blind you?
I think it would involve the word 'fatal'
I know it is possible to survive being hit by lightning, but it's not something you'd want to bet your life on
I didn't know that lightning was static. So this thread has taught me something.
We aren't precisely sure how lightning is created.
