How much difference does fast memory make?
On a system that cheap money is DEFINITELY better spent elsewhere. Just get a cheap-ass dual channel kit, although obviously make sure you get enough of it (2gig ideally).
Gfx card (if gaming) and CPU make vastly more difference to performance than memory speed/timings in the majority of situations
The price to performance ratio on high speed RAM is incredibly low. But if you already have the best CPU and Graphics card, what else is there to upgrade to get better performance? Some people just feel they HAVE to have the best, no matter the cost and this is why they make high speed RAM. For a £400-500 budget on a whole PC, a cheap 2GB "Value" kit will be more than ample. I wouldn't spend over £75 on 2GB and preferably less.
So would it be worth just getting some cheap value 2x1GB GeIL 6400C5 http://www.overclockers.co.uk/showproduct.php?prodid=MY-064-GL&groupid=701&catid=8&subcat=
the 2x1GB Ballistix 5300 for £64 http://www.overclockers.co.uk/showproduct.php?prodid=MY-088-CR&groupid=701&catid=8&subcat=
or paying £70 for the OCUK 2x1GB 8500 sticks http://www.overclockers.co.uk/showproduct.php?prodid=MY-013-OK&groupid=701&catid=8&subcat= ?
- bit concerned about all the stories of constant RMAs with the ballistix.....
