Quesiton is, why do you want it on 24/7?
That's awfully expensive, 7.6p per KW is much more reasonable
Who is offering electricity at 7.6p per kw?
British gas do 22p for the first 125KW per quarter and 7.6p thereafter on their Click Energy 5 tariff.
And that is listed above
But for that theory to work, you would also need to take into account the 22.43p per kWh before the 125 KW and average it out, which would make it quite a bit above 7.6p kw.
But pc cost should be marginal. I'd imagine even without a PC a household would use at least 125kWh a quarter.
Also, I'm on click energy 5 and get 20.229p and 7.771p respectively. Why are yours different?
British gas are not thick, they are not going to charge over 4p per Kw less than their closest competitor.
When the averaging out is done it will be a figure much closer to 12p per KW.
When it is averaged out for our household it works out as 8p per kw/h. For anyone using 8,000 KW/h plus, british gas are significantly cheaper.
When it is averaged out for our household it works out as 8p per kw/h. For anyone using 8,000 KW/h plus, british gas are significantly cheaper. It's all about economies of scale.
Can someone give me a number for cost per hour of running average PC
tbh its not good for you to need a completely dark and silent room to actually sleep
