how much does watercooling lower temp by?
I'm burning out aircon units where my rigs are :(
lol what the hell have you got running? i use just a single unit cant rememebr the btu size but it keeps the room cool or it can go damn cold in the summer but i run it just to circulate fresh air most of the time anyway tbh
cant stand being hot indoors in the summer outside heat is fine indoors i like it cool
It's less what I run rather than how I run them. Let's just say I'm looking at solutions that remove the ambient from the equation.
couple ways about it remove all heat from the pc directly outside, duct everything externally, or cool the ambient enough but still needs to be comfortable such as A/C
yup the Hailea type of thing, vented out sid eor in another room or the underfloorboards build someone did on here a while ago
ive been thinking of that route also can take the water down a lot more then
