NathanE said:The idea is to keep as much stuff in memory as possible. Free memory is wasted memory.
http://www.google.co.uk/search?q="Free+memory+is+wasted+memory"Craig321 said:lol![]()
more free memory = faster pc
Craig.
NathanE said:
How can a computer that has a lot of free memory be faster, that doesn't make senseCraig321 said:Of course free memory is wasted memory, but free memory is faster computer aswell.
msn the other usual crapDutch Guy said:How can a computer that has a lot of free memory be faster, that doesn't make sense![]()
Basically you need as much stuff in the memory but still have enough free to load a game.
marc_howarth said:My PC idles at around 190MB but only having 256MB of RAM i like to keep as much memory free as possible
Correct, but why is that do you think? Because the OS will be able to store more stuff in memory!Craig321 said:you should get another 256mb stick, you'd see a big difference.
Maybe the one using more memory will have more running programs and therefore be slower, not because of the memory used?Craig321 said:Check out the difference between load times (as in opening a new program) with a PC using loads of memory and a PC using less memory.,
Correct. The more software that is open the more threads your processor(s) is context switching between. As long as memory usage is less than the total amount of installed physical memory then disk swapping is kept to a minimum and virtual memory access performance remains constant.Dutch Guy said:Maybe the one using more memory will have more running programs and therefore be slower, not because of the memory used?
