- 9 Jan 2005
- Stoke-On-Trent
I am sure it would be bottle necked by my i7 6800k. There is a slight bottle neck even if I went with the 2080 Ti. That's why I want to upgrad my entire rig.
Not sure if this helps but I upgraded from your same gpu and cpu to a ryzen 3600.
Not sure why (the cpu bottleneck benchmarks posted earlier would go against my experience) but I 100% noticed games feeling considerably smoother. That's about it.
I got it for super cheap though (sold 4770k and it cost me practically nothing).
I game mostly at 4k. This was a challenge with a 1080, even overclocked with +170 core and +700mhz memory, but I'd say the 3600 upgrade helped with maybe 1-5 fps (quite a lot when you're at 40-50fps).
In assassins creed however, it nearly gave me extra 50%... But it still runs like **** even at 1440p
I then upgraded to a 2080 (non super), which is only an extra 25% or so over the 1080 but again noticed only small uplift in fps but more smoothness. Just ironing out those 1% lows.
It's a shame I don't know how to measure 1% lows... I think that's what I experienced.
Anyway - yeah, as always, you'll gain a tiny bit from a better cpu, and a whooooole massive chunk of fps from a new gpu.
Do gpu first, for sure, then get a new ryzen zen 3 4700x or maybe even wait till zen 4 (gaining you ddr5 and a massive 4+ years am5 socket lifespan of upgrades). That's what I'm gonna do, even if zen 3 kills intel - my 3600 will still be capable of 4k @ 60fps for years to come with a 3080. I think your 3770k will be too.
Hope that helps
Qled over oled because oled has been known to cause burn in which can be an issue on windows (desktop task bar eg).
sadly the display is long out of warranty. To be fair it does spend a lot of time sitting static on the same screen.Nooooooo!! But hang on... So your burn in wasn't on an oled?I've got lovely horizontal burn in type lines on one of my systems along the edge between the task bar and desktop background and navigation bar and web-site content in Firefox - even with using a blank screen screensaversadly the display is long out of warranty. To be fair it does spend a lot of time sitting static on the same screen.
I've not generally had too much problem with OLED though in that regard.
I suspect a lot will be those 1% lows - minimum FPS and/or overall frame pacing can (and will) be better with a new Ryzen or Intel CPU which can be noticeable even at approx. the same FPS though it shouldn't be a huge deal outside of 1-2 games that probably benefit a bit more - I guess it depends a bit on what you play.
Some of it might come from:
-Fresh new OS install (often improves things immensely - depending a bit on your housekeeping).
-Amount of background and/or other tasks - these days a 4000 series i7 may require you to close other applications, etc. while something like a Ryzen 3600 might get the same smoothness or better while other tasks are active.
Coming up to the point I'm considering upgrading my 4820K but just not being pushed over the edge yet - I suspect the quad channel on the X79 platform is providing some benefit that the 4770K might not be seeing however.
PS had a play with a 3600 + RTX2060 few days ago so not entirely wildly conjecture on my part - built quite a lot of Ryzen 2x00 systems but not had much opportunity to spend much time with the 3x00 CPUs yet.
What display/devices? Windows devices?It is but in general I've not had that issue (I've more than one display/device that uses them) but it can happen![]()
Not really "hurting" - as already shown, at 4k/60, where the op will be gaming, the 4790s lack of power is still pretty insignificant, even when compared to a 10900k... which will probs be the case in almost every single game.I wouldn’t worry about the word bottleneck so much, but it probably is time to lay your trusty steed to rest. Your CPU will be hurting in cpu intensive games and you will see the difference if you upgrade to a modern build.
Yeah some of the recent games performance drops off a cliff on older i5s, etc. but the i7s still hang in there.
We are starting to see games now though where 10-12 threads whether real cores or SMT is starting to become more required.
Get a 6 core Xeon in that X79 rig of yours Rroff - i had an old mac pro chip that did 4.7 on very reasonable volts - you'll get one for £75
I've considered it but the only ones worth going for are the E5-1650 SR1AQ or 4930K both of which are usually £150+ from reputable sellers or the 8 core 1680 which is usually £300+. The rest don't overclock on 2011-2. Probably money better put towards a new build.
EDIT: Few cheaper ones on the bay again.
and yet there are other pleps online saying an i7 7700k will be a massive bottleneck with a 30 series card. clearly they just want a card themselves so they chat **** to make others waste money on a cpu upgrade that will do **** all.
