How much power does my computer use
17 Jun 2012
North of Ireland
Is there any programs to tell how much power my computer uses. I have heard of the estimate programs and a kill a watt but i was wondering is there a easier and cheaper way to do it.
The best method is to get a kill-a-watt like device, such as the one Surveyor has linked to. They are much more accurate than software, plus you can use it on other devices like speakers, monitor, fridge, etc...
Its just that i used one of those estimate programs and with hdd 2 ssd single gtx670 etc and a overclock it says im hitting 700 watts. Only have a 600 psu.
You guys are right probably worrying over nothing.
If your PSU is digital (like Corsair AX-860i - with "i" at the end), you might measure wattage by software AFAIK, otherwise it will be just estimation depending of knowledge of programmer.
Better way is to buy multimeter and you'll see then. It doesn't cost much.
You did something very wrong to get a figure like that. It would help if you told us your spec.
Did you set your CPU count to the number of cores your CPU has? :D
That is a common mistake people make on PSU calculation sites. You need to select 1 CPU.
No just the one cpu
I have ocz 600watt psu
Forumla v motherboard with fx8150 oc to 4000ghz
gtx 670 gigabyte x3 overclocked
4 sticks of ram running 1.5v 12gb
A toshiba 2t hdd
2 samsung sdd 120gb + 240gb
xonar dx2
pci wifi card
Kular h2o 920 water cooler
2 x 200 mm led fans
blu ray drive
4 usb peripherals plugged in
thank thats it and all that brings me to 700 watts
Its just that in some games i get stutter and microstutter and what i think it could be limited power please tell me different.
it wont be anywhere near 700W, i think you are usually looking at ~50-150W for the CPU, 100-250W for each GPU and then less than less than 50W for the rest, bearing in mind you would have to be running the cpu and the gpu at 100% load to pull the absolute max, which is never going to happen outside stress testing.
Those calculators use maximum values for everything - they assume 15W or similar per HDD, whereas in reality they typically pull 7-10W at full load. They'll take the CPU's full TDP, which only applies if you're at 100% load on all cores.
They then assume that all of this is working at the same time: in reality it's very rare for your CPU, GPU, sound card, HDDs to ALL be raped at the same time - typically your system at high (stress test) load over a full minute will use something like 95%/60% CPU/GPU, or 80%/90% CPU/GPU, with little HDD involvement). So they add all the numbers together, which isn't necessary.
They also add in a margin for error, a margin for expansion (most people add a few HDDs and fans over the life of a PC), some extra for USB devices, a margin for error on those, a percentage because of capacitors losing capacity, and some even assume that you'd rather pay more for a more powerful PSU just because it's more efficient at 80% load, so add 25%.
And don't forget that your PC will very rarely be at high load, and that your PSU can usually supply a peak load above it's nominal load. Typically 125% of rated performance for short bursts.
In reality a mid range-high end, single GPU PC typically draws something like 250-350W. Add in a little extra for overclocking, the PSU losing capacity over time, upgrading your GPU later and you arrive at the figure most people go for as a minimum: 450W, with most people taking a 500-600W PSU just for the extra headroom and peace of mind.
Even a dual GPU overclocked system typically only draws 500-600W at load. Again, people tend toward a little peace of mind and headroom (often these PSUs get used for more than one build) and so end up with 700-800W PSUs.
The 1000-1500W PSUs are only worthwhile for heavily overclocked, water cooled, dual or triple-GPU systems which need the extra power security.
