My minds turned back to car care recently after a long spell of having a car I could grow spuds on
and I've been thinking- just how often should you polish a car?
The reason that I ask is I polished up just my bonnet the other day and gave it a coat of pure carnauba wax. I then went on to give the rest of the car a quick going over with Turtle Wax Speed Wax (spray on>wipe off>let the haze evaporate type stuff) Afterwards, the whole car looked great, the bonnet looked no better or worse than the rest of the car deapite me spending more time on it than the rest of the car put together. I'd last polished the whole car last May.
So I'm now thinking that as long as the paint surface is shiny theres no point in polishing at all?
I used to polish my car just once a year but tbh I'm considering leaving it until it starts to look like it needs a polish? Is this a bad idea? I was considering sticking with my yearly coat of pure carnauba but I'm not sure about putting this straight ontop of other wax?
I've also invested in some Auto Glym intensive tar remover as currently if I get tar marks I polish them off, I thought this would be a better method?
I must admit that I do go OTT with waxing. Everytime I wash my car (currently weekly) I spray onto the wet bodywork some Wax It Wet or Speed Wax and wipe off as its quicker and easier than getting the leather out
Just after a bit of advice really. My car does normally look bloody good if I do say so myself but just want to do whats best in terms of keeping it that way.
and I've been thinking- just how often should you polish a car?The reason that I ask is I polished up just my bonnet the other day and gave it a coat of pure carnauba wax. I then went on to give the rest of the car a quick going over with Turtle Wax Speed Wax (spray on>wipe off>let the haze evaporate type stuff) Afterwards, the whole car looked great, the bonnet looked no better or worse than the rest of the car deapite me spending more time on it than the rest of the car put together. I'd last polished the whole car last May.
