Video is up.
I turned my volume up and would say my chassis/cpu fans are noisier than yours so prolly I am used to the noise.
Just had a fiddle in the BIOS with my Chassis and CPU fan settings. So much quieter
I have dropped my cpu to 4.4 also, so don't/shouldn't need the cpu fan on full continuous. The only thing I can hear now is my GPU and it is ok but I wouldn't mind it a lil quieter. Maybe that Arctic cooler could be an asset![]()
Depending on price and length (it looks lengthy at 3 x 92MMs) I might give it a spin.
Looks the business though.
Mine are all on a fan controller running at 800rpm. While my cpu is considered old now the 955BE never passes 48c on full load at 3.8ghz.
Get a fan controller and you can crank up the fans when you game. I take it you have your cpu fan plugged into the cpu fan header for bios tweak?
It is very lengthy! The 680 is'nt even that long is it???
It's the same cooler(apart from the mounting bracket/heat sinks) that tamed the mighty 480:Liking the look of this thing:
Another update, Witcher 2, 1 hr play through temps(Only CPU fan On, NO case fans on):
