The pit lane entry means going straight on at Vale. The tarmac for it was down before last years F1 event.
I belive this new pit lane will be used for anything using that part of the track. If BTCC decides to use the half of the track that uses the new pits then they will.
Also, as with the Abu Dhabi track, Silverstone can now be split into 2 fully independent circuits which can be used at the same time.
that is possible, there is a conection on the exit of the arena section that joins the exit to the start of the hanger straight, but to be honest i don't think its going to happon.
Here is a picture, just look at the hair pin in the arena section.
But.......what have silverstone done to the magical bridge corner!!!!! i just found this image
i just prey the old part of the track will still be in use.
) but some how, i think not
