How slow are external drives?
Suspended
30 Aug 2004
How slow are thye compaired to normal 7200 drives? I dont want to be sat for hours backing up 50gig or anything. Especially as ill be getting a 500gb
As rocketman says the drives are exactly the same as the internal ones so you could swap it for the one in your current PC and find no performance difference but unless you use USB 2.0, Firewire or eSATA then you will suffer.
it will be slower if you use USB 2.0 and Firewire as it will bottleneck the drives.
Something like eSATA would be very fast though.
Yep usb2 i think. whats eSATA?
im lookin at this one
LaCie Black 500GB USB2.0 External Hard Drive (301285)
500GB Capacity, USB 2.0 Interface, 7200RPM Spin Speed, 16MB Cache, 2 Year Warranty. At just a little over 12p/GB the LaCie Black 500GB USB 2.0 External Drive offers simple and cost effective storage.
Or the WD sata internal one for the same price
will be using for videos, music and maybe games aswell
eSATA is external SATA, it is just a different connection standard that gives you the same sort of speeds as you would have from the internal connection. Some motherboards have the ports but I think it is mainly on newer motherboards. :)
External hard drives are much slower than internal (USB and firewire) I also don't trust USB connection, have lost data. I'd use esata, or buy sata removeable cages.
Faster than most peeps internals ;)
WD My Book Prem ES 500GB.
