Permabanned
- 9 Dec 2010
Then don't upgrade.
Then don't upgrade.
Indeed! I'm astounded that an I7 seemingly offers so little improvement over a Q6600? Seems bonkers!![]()
Some of those charts suggest the exact opposite. Those figures make an upgrade for me look utterly worthless...?
Depends on what i7 you are comparing against. I noticed an improvement going from 2007 to 2012 tech.
Those are averages, the minimum FPS has probably increased by more. Also, BF3 is old, expect to see the gap widen with newer ones, e.g. Metro LL.
That said, most of the time the GPU is way more important. A £100 CPU will generally be plenty for a high end GPU. It's only really crossfire/SLI (or a few really CPU heavy games) where you need an expensive CPU.
But I digress...
Shows a huge increase in gaming performance moving to an i5-3570k in Borderlands 2, Crysis 3, Far Cry 3, Starcraft II etc. And that's a better Core2Quad than yours, and a stock-speed 3570k.Toms Hardware did a cross-generation lab test a few months back. They used a Q9550, but it gives you an idea of gains in a few games;
http://www.tomshardware.com/reviews/ivy-bridge-wolfdale-yorkfield-comparison,3487-9.html
A significant jump moving to a modern i5
Did you not look at the link I posted?
Although, they did use a better GPU than you have.
i7s don't usually offer much extra performance over the i5s in games.
Basically on a lot of titles the minimum FPS is 50+% higher!
Which is more important than having > 120 fps if you do not have a display that requires it.
I've yet to overclock it
. My SSD finally reaches it's rated transfer speeds too. Gaming wise, I ran a few benchmarks before upgrading and in all cases my min FPS increased dramatically (in Valley 1.0 it doubled) but max FPS only improved slightly. Played Arkham Origins last night and any previous slowdowns were gone. As well as minimum fps greatly improved , i find this overall leads to a much smoother gaming experience.
Going down the pc gaming route will enevetively lead to required upgrades
since ive added a gtx 670,i find gaming at 1080p is now a complete superb gaming pleasure(with all settings on ultra)
But then I'll upgrade and expect a double/tripple frame rate increase!
Yesterday I upgraded from my 3.4 Q6600 to an FX8320 (Kept my HD6950 for the time being). Performance wise there isn't any particular wow factor, it is most certainly quicker though. But, instead of venting hot air from my rad at idle & very hot at load, it now blows cold & a little bit warmI've yet to overclock it
I spent £320 on an FX8320,990FXA-UD5 & 8GB of Geil Potenza, money well spent in my view, I should be able to recover some of the cost if I sell the Q6600 setup on. Would've preferred Haswell but very happy with what I got.
Last night I was playing "State of Decay" at 1680x1050 on my Radeon 7870XT (Q6600 at 3.4ghz). In high graphics quality it was running at about 25-35fps. In medium it was up to about 55-70.
