What will a hub do for me?
Got into this over the weekend. Home Assistant running in a Docker container on my Unraid server, just the single Philips Hue bulb and V2 hub at the moment. Home Assistant looks very powerful, looking forward to trying some other stuff with it![]()
Currently have whole flat of Philips Hue bulbs and light strips but in the process of buying a house that has multiple rooms with arrays of spotlights.
These IKEA TRÅDFRI LED bulb GU10 400 lumen bulbs seem to fit the bill for a decent price, anyone had any experience with them?
Can anyone recommend some Alexa compatible bulbs, the Philips Hue ones sting a bit a £12 a bulb.![]()
Thanks, will do. As the configuration is in one directory on the Unraid server, a backup should be straightforwardWelcome to the club!
Just a big hint, look at a solution to backup your config. After you've tinkered with it for a while your UI well be set up specifically, you'll probably have a number of automations and scripts, the whole thing will be a nightmare to put back together if your config gets corrupted/destroyed etc.
Anyone found good automation for blinds that work with alexa and ifttt?
Would like to open close them on command but also have them close in time with sun rise/ sun down.
Don't want whole blind systems but something that can control the current blinds.
Worcester/Bosch Smart TRVs are £37.99 today at the rainforest. Just nabbed 4 to get my heating set up properly. Bit pointless just having the one thermostat imo!
This is something I want to get but not sure on the exact compatibility. I have nest installed which is great but in the evening I want my lounge and downstairs to be warmer in the evening and then bedroom to be warmer before bed only and then cooler in the morning as my missus gets up before me. Woild it be possible with any existing smart trvs and my nest?
I just want some flexibility to adjust the TRVs based on the individual room temp as the heating is on enough at this time of year to make use especially in these two rooms. Like @matt100 I have other sensors that I could use but unsure if some of these TRVs would work.
You only get smart TRVs that work with competing thermostats as far as I know, so basically you can use the hive/bosch/tado TRVs but that requires getting rid of nest.
Which in and of itself wouldn't bother me other than the cost and disruption because I really don't fancy having a go myself, especially the TRVs
The Bosch TRVs say they work with Alexa, N
IF you already have manual TRVs, then it's just a case of unscrewing the old ones, and screwing the Smart TRV on in it's place. You don't need to drain the system. I've already removed all the manual TRVs here ready to install the Smart ones when they arrive later.
Hadn't thought about that tbh... good tip
