I am thinking of reseating my Zalman CNPS9700 as according to Core Temp on my Q6600, Core 0 is circa 4 or 5 degrees C hotter than the other 3 cores.
My question is, how do you guys apply your thermal compound, a grain of rice size blob and swivel the CPU cooler or a diagonal strip across the CPU, or is there a 3rd option
Thanks
Syd
Thanks
Syd
I always apply a small grain of rice sized amount and then let the weight of the cooler spread it out.
