How to check for bad sectors?
6 Jan 2006
Midlands
Hi
ive just bought a used harddrive and need to check if it has any bad sectors or any problems with it. How do i do it?
thanks
Either use the diagnostic disk from the HDU manufacturer's website or plug it in and run a chkdsk on it from within your current Windows. Check what drive letter it has been assigned and open up command prompt and type at the prompt:
chkdsk d: /p /r (if the drive letter is 'd') etc.
Probably better to use the manufacturer utility though - see the HDU sticky.
