how to clean a bed
12 Feb 2006
Surrey
my brother will be having my bed as i will be getting a new one soon however it's a little dirty, not too bad but got 2 tea stains, got a mark where i removed the lable a while ago where its lighter under the label.
anyway can anyone reccomend anything to clean it up, freshen it up, and remove the stains if possible. i was origirnally going to get some febreeze to freshen it up but now seeing the stains and that i need something i bit better.
I rekon a regular carpet washing hoover will do a decent job on the mattress.
Is it a devan or a regular frame?
You could hire one from the local dry cleaners probably. I bet your carpets would love you for it too ;) :p
I swear by my Vax cleaner, but it's not the upright version. IIRC, it knocked me back £130 at time of purchase 6 years ago, but it's a worthwhile purchase!
I'd replace the mattress if its more than five years old really. I'd probobly use a foam furniture cleaner if I had to clean one though.
