I can mince your titan score on Unigine valley.
EDIT
Having looked at the score, maybe not mince, but certainly beat.![]()
EDIT
your idea of normal or unrealistic is not the same as mine, many people take the correct steps to keep their hardware cool
I actually game on my cards for hours at a time and they never throttle due to heat as I have my cooling set up to prevent that from happening
as I said, I don't care if someone else has heat management issues, when I look at purchasing a card I want to know what it is capable of when you remove backround heat as an issue (as it's one I never have)
@LtMatt
My single Titan challenges your mincing HD 7950s to a duel at these settings.
Do you accept the challenge.![]()
Taken from the Valley thread.
My £360 dual 7950's - Score 3865 - 7950 CF @ 1200/1600 - LtMattt
vs
Your £850-£1k Titan - Score 3172 - GTXTitan @ - 1011 / 1661 -Kaapstad
You are not up for a little challenge at the resolution I posted, you should win easy shouldn't you ?
You ain't tricking me into that lower resolution malarky with your 6 core cpu.![]()
6 cores make no difference on the Valley bench, in fact they are at a slight disadvantage compared to a quad core.
Don't forget I am the one with the single card here.
Come on what are you afraid of.![]()
If you can beat the score ive posted ill consider it, otherwise i don't see the point.
And I thought you liked a challenge.
LOL
A bit too much mincing going on here for my liking...
There are three GTX 770s on the heaven bench thread that are above my Asus Matrix Platinum HD 7970 (which allows overvolting up to 1.4v). My HD 7970 in turn sits above all the HD 7950s, I would say the GTX 770s are quite capable of seeing off all the HD 7950s and most of the HD 7970s.
Your argument is busted
You really should give NVidia cards credit where they deserve it, despite your dislike for NVidia.
Remember the Heaven 4 bench is more demanding on GPU graphics performance than any of the other benches.
My argument isn't busted because you're talking about heaven, it's a benchmark that isn't representative of game performance.
