I’ve recently had a new bathroom fitted and need to install a blind. The holes I need to drill are only 6mm, but I want to try and make sure I don’t crack the tiles!
Someone said that if I started off the hole by hand it would reduce the chances of the tile cracking.
Does anyone have any tips?
Thanks
Thanks
